    Cut ESC to Receiver wire... any suggestions?
    Tekin_Tim
    Post by Tekin_Tim on Sun May 12, 2013 8:49 pm
    Like an idiot while I was soldering my new Tekin I got careless with the solder iron and melted through the wires that connect the receiver. Aside from soldering them back together and making a big booger job with electrical tape anyone have a nice clean, secure idea?
    rcracer207
    Admin
    Re: Cut ESC to Receiver wire... any suggestions?
    Post by rcracer207 on Sun May 12, 2013 9:49 pm
    Your solder and electrical tape booger fix is the easiest and quickest probably. The other thing you could do is use a set of small male and female bullet plugs like the ones used on lipo balance plugs but that's more time and money.
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJPY0&P=7
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJPY1&P=ML
    mtrucker
    Post by mtrucker on Mon May 13, 2013 7:43 am
    Solder it and use the right size heat shrink tubing,,good as new!
    RAZORBURN
    Post by RAZORBURN on Tue May 14, 2013 8:57 pm
    You can also buy the jct connectors and just make a new connection. If you solder them I always step splice them so your splices are not all in the same area, this helps keep the bulk splice down.
    http://compare.ebay.com/like/300829741556?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
    Fixerdude
    Post by Fixerdude on Wed May 15, 2013 5:32 am
    Good advice. Staggered splices are always the way to go. Might also want to use heat shrink tubing that has glue inside. Widely available, and makes a water tight corrosion free connection!
      Current date/time is Wed Feb 21, 2018 2:03 am
