    Fly Sky FS-iT4 4 Channel 2.4ghz Telemetry Radio System (Orange)
    Losi
    Post by Losi on Tue Apr 02, 2013 10:29 pm
    i have a nice 2.4 Fly Sky FS-iT4 4 Channel 2.4ghz Telemetry Radio System (Orange) 4 sale i would like to get $150.00 for it. her is all the info on the radio and the website where i get it from used it 3 times.. i can text anyone pic of it just need ur cell number
    http://www.hobbypartz.com/
    The FS-iT4 is Fly Sky's newest 2.4ghz radio system. This Fly Sky radio is loaded with tons of features that allow the user to easily configure their radio control model. The iT4 is capable of storing 20 models in its internal memory and has the ability to graphically represent all trim, exponential, and dual rate adjustments. The graphical representations are extremely useful in depicting how the car will react to the parameter changes. The switch and trim buttons surrounding the steering wheel are fully programmable allowing the user to program each specific button to do a specific task manually assigned. The steering wheel housing pivots allowing the driver to configure the steering wheel angle for the ultimate comfort. Comfort can be further enhanced by the removable rubber pistol grip. Two sizes of small and large are included in the radio package.
    The iT4 features a second-generation automatic frequency hopping digital system transmitter (AFHDS 2) capable of receiving transmission parameter information, such as voltage, temperature, and speed from the receiver. In other words, this radio features full telemetry function with the ability to piggy back multiple sensors. The iT4 comes equipped with voltage, temperature, and speed sensors ready to hook up to the receiver. An additional serial bus receiver is also included for additional servo wiring.
    The FS-iT4's large screen display features touch screen technology allowing greater convenience in parameter settings. A stylus is also included to protect the screen from scratches especially when your fingers are caked in grease, grim, and dirt from working on the vehicle.
    The FS-iT4 is powered by a single 3.7v 1200mah Lithium Polymer Battery and is charged via a micro USB port on the transmitter. The radio can be had in two flavors; chrome black and orange crush.
    Features:
    Servo Reversing
    End Point Adjustment
    Sub-trim Adjustment
    Steering Exponential
    Steering Speed Adjustment
    Steering Mix Adjustment
    Throttle Neutral (Dead Zone) Range Adjustment
    Throttle Exponential Adjustment
    Throttle Curve Adjustment
    ABS Braking Programming
    Throttle Speed Adjustment
    Throttle Centering Position Programming
    Throttle Idle Up Programming
    Engine Cut Programming
    Boat Mode
    Brake Mixing
    Full Channel Mixing
    Servo Movement Display
    Race Timer
    Key Programming
    20 Model Memory
    Transmitter Specifications:
    Channels: 4
    Model type: car/boat
    RF range: 2.4-2.48GHz
    Bandwidth: 500KHz
    Band: 160
    RF power: less than 20 dBm
    2.4G system: AFHDS 2
    Code type: GFSK
    Sensitivity: 1024
    Low voltage warning: yes(less than 3.5V)
    DSC port: yes(USB; output: PPM)
    ST range: 90
    TH range: 45(F: 30;B:15)
    Charger port: yes
    Power: 3.7V(1200mAh)
    Weight: 347g
    ANT length: 26mm
    Color: black
    Certificate: CE0678, FCC
    Receiver Specifications:
    Channels: 4
    RF range: 2.40-2.48GHz
    Band: 160
    RX Sensitivity: -105 dBm
    2.4G system: AFHDS2
    Code type: GFSK
    Power: 4.0-8.4V DC
    Weight: 15g
    ANT length: 26mm
    Color: black
    AS-Bus PORT: yes
    Data Acquisition port: yes
    Included in Package:
    Fly Sky FS-iT4 AFHDS 2 Transmitter
    Fly Sky FS-iR4 AFHDS 2 Receiver
    FS-SEV01 Serial bus receiver
    FS-BA1200 Lipo battery
    FS-PEN01 Stylus
    FS-SPD01 Rotation speed telemetry
    FS-STM01 Temperature telemetry
    FS-SVT01 External voltage telemetry
    Bind Plug
    Additional Rubber Grip
    Micro USB Charging Cord
    Losi
    Re: Fly Sky FS-iT4 4 Channel 2.4ghz Telemetry Radio System (Orange)
    Post by Losi on Tue Apr 02, 2013 10:39 pm
    Losi
    Post by Losi on Tue Apr 02, 2013 10:40 pm
    Losi
    Post by Losi on Tue Apr 02, 2013 10:42 pm
    Losi
    Post by Losi on Wed Apr 03, 2013 8:13 pm
    SOLD SOLD SOLD SOLD THANKS FOR LOOKING
      Current date/time is Sun Feb 18, 2018 3:01 pm
