    help with a traxxas vxl esc
    nitro_guy
    Post by nitro_guy on Fri Feb 08, 2013 9:51 pm
    im having issues with my vxl 3s I'm use nimh battery used it turned it off and now all i get is a solid red light and thats it any help thank you
    cjroy1998
    Re: help with a traxxas vxl esc
    Post by cjroy1998 on Fri Feb 08, 2013 10:02 pm
    if i were u i would put this on the traxxas forum.
    heres the link
    http://traxxas.com/forums/
    i would go under what ever model truck u have this in.
    nitro_guy
    Post by nitro_guy on Fri Feb 08, 2013 10:09 pm
    easyer to send it back to traxas and for $50 i can get a new one
    Evolution Hobbies
    Post by Evolution Hobbies on Sat Feb 09, 2013 3:37 pm
    check to make sure you didn't change a setting on the radio,specially your neutral setting.Also if you have a newer vxl with a TQ 2.4g series radio make sure the radio is still binded to the receiver .I have seen people have a issue's with the new radios and Rx.Also if all else fails try re calibrating the radio to the Esc.
    Hallin Harry
    Post by Hallin Harry on Sun Feb 24, 2013 1:20 am
    also all traxxas esc the color lights mean solid red NIMH mode solid green lipo mode if it solid red and no movement from it make sure ur power button aint sticking i had that issue before ....
    nitro_guy
    Post by nitro_guy on Sun Feb 24, 2013 9:38 am
    okay
    GingerGuy
    Post by GingerGuy on Sun Jun 30, 2013 1:18 pm
    Try to re-calibrate it.
    rcracer207
    Admin
    Post by rcracer207 on Sun Jun 30, 2013 6:28 pm
    nitro_guy wrote:easyer to send it back to traxas and for $50 i can get a new one
     I wouldnt waste the $50 if I were you.  If it does end up being junk you would be much better off just putting the $50 towards an aftermarket ESC.  You can get a brushless ESC that will handle 3s for under $100.
    Traxxas Brushless ESC's = Constant Headaches!
      Current date/time is Wed Jan 17, 2018 5:31 am
