    B4.1 shock oil question
    drframing
    Post by drframing on Thu May 17, 2012 12:01 pm
    I recently got a B4.1 and I'm going to be racing it at Evolution raceway in Casco, and I was looking for some guidance on what shock wt oil to use. Any suggestions would be appreciated. Any info on tire choice would be good to.
    Thanks
    rcracer207
    Admin
    Re: B4.1 shock oil question
    Post by rcracer207 on Thu May 17, 2012 3:30 pm
    I cant help you with the shock oil question because i dont run 1/10 buggy but for tires i personally like pro line hole shots best. Ive used the new blockades and they work well too. Snipers also work well. Smaller pin tires with a tight tread pattern hook up well.
    My opinion, others may like different tires.
    Hope that might help a little.
    Evolution Hobbies
    Post by Evolution Hobbies on Thu May 17, 2012 4:06 pm
    Dan
    I think some use 25-35wt oil in some of there buggies.Higher weight in the front.
    crownguy
    Post by crownguy on Thu May 17, 2012 8:09 pm
    check out associateds website for the set up sheets, pick something thats close to evolutions and tweak it from there
      Current date/time is Tue Jan 16, 2018 10:23 am
